oil pan SBC
barnyard
have 2 oil pans For SBC. one w/ drain in center, other w/ drain in side, which is better? Is there aftermarket valve that is durable to help oil change easier?
stresspoint
i find the side outlet better on boats , cars i prefer the rear center.
get a dipstick sucker pump , best way to get oil from a boat motor.
i suck as much out as i can get then put a tub under the motor and pull the drain plug to get the remaining liter or so out.
nola mike
Get a remote oil filter kit while the engine's out. These jokers only deal with the dipstick because they have to :p
Center is a 4x4 truck pan and is more of the standard "marine" (industrial engine) offering
Usually the dipstick determines the pan
