Oil pressure alarm
Afternoon,
My understanding is the oil pressure alarm was an optional extra with Sea Ray that the original owner must not have opted for.
How easy is it to connect one up? Is it simply off the back of the oil guage?
I have also read of low gear oil alarms, quite sure the boat doesn't have any alarm for these types of things. Be good peace of mind to have these in place
Boat is a 203 sea ray 180br
Motor is a mercruiser 3.0
Re: Oil pressure alarm
Btw I'm basing my wild guess I have no alarm on having the ignition turned to on (not acc) and hearing nothing. Have looked under the dash and see nothing that looks like it would be an audible alarm.
Fun Times
Hi there, what year is the boat? Have an engine serial number handy?
Fun Times
The parts you would need to set the up warning horn system will be found in the "C" area.
http://www.mercruiserparts.com/Show...44.png&inbr=4893&bnbr=60&bdesc=Wiring+Harness
http://www.mercruiserparts.com/Show...br=290&bdesc=Oil+Reservoir+Bottle+and+Bracket
Mercruiser Oil Pressure Switch, 87-805605A1 plus you'll need a tee connection like from NAPA (two parts...#3327, and 3700).
Mercruiser part # 806193A46 RESERVOIR, Oil-Bottle
Mercruiser part # 48952 Sender, Switch Assembly, Temperature, Mercruiser
The inline 4 cylinder has to use the red switch, while the V-6 and V-8 use black. They have different temperature thresholds...the V-6 and V-8 being higher. Run the part number in ebay to see what the red switch looks like.
Your complete parts catalog for you. http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=804862+99
