Oil pressure sending unit
Brian D
How can you tell if your oil sending unit is going bad? I have a Volvo 7.4GI PBYCCE.
boat127
Re: Oil pressure sending unit
get a manual and test it.
get a mechanical oil pressure gauge and remove the oil pressure sender and hook up you mechanical oil pressure gauge and see what it reads.
your best tool is a service manual
180shabah
ditto the manual and mechanical gauge.
Brian D
Understood. My manual's on the boat but I'll check it out. If I purchase a mechanical oil pressure gauge will the fittings supplied with it fit my block?
Thanks again for the advice.
Ayuh,... If it comes with 1/8" pipe fittin's..
