oil pressure?
Last trip I noticed my oil pressure on a mercruiser inboard 350 tourn skier to be around 10psi after running at idle. Under load it would go up to about 30-40psi. Does that seem too low? Time for an oil pump replacement? Serial number: 0k040853
Bt Doctur
if your using anything but 25W-40 that can happen. lower oil pressure after a hard sustained run.install a mechanical gauge to verify the electrical one
500dollar744ti
10psi per 1000 rpm is within specification.
Replacing the oil pump does not solve 99% of oil pressure problems. The only way it would fix something is if the pump was physically broken, and if it's pumping oil, it's not broken.
Lowered oil pressure is a result of engine wear and increased clearance in the bearings.
Agree with all, and my engines after coming off plane are a bit under 10, then as it cools down it comes up a bit more. I run straight 40W because if I have to put a jacket on I'm not going boating ;)
Starcraft5834
My 3.0 presents same #'s.... round 10 at idle, 30-50 at WOT. I run Quicksilver 10-30. I'd say your fine..
