Oildyne trim pump question (update)
bigbob_FTW
No trim. I can jump the hot and up and down circuit and the pump runs. I think the problem is between the switch. no bad fuse in the loop. any suggestions on how to diagnose.
bigbob_FTW
Re: Oildyne trim pump question (update)
Ok, found a loose plug at the control handle. Plugged it back up and I have up and down and down trim but no up trim. testing further.
Bt Doctur
check the trim limit switch,
