Ok OK OK, Lubedude? Whick best synthetic? AMsoil, Mobile 1 or ?
Heinz CA.
Re: Ok OK OK, Lubedude? Whick best synthetic? AMsoil, Mobile 1 or ?
and uses maybe a quart every 3500-5000 miles
LubeDude
Originally posted by Heinz CA.:<br /> Ok so good grief whats best for a 4.0 XJ I drive daily at 70-80 mph w/ 164k and runs like a top?
Sounds like whatever you are using is working fine for you.<br /><br />Seeing that you are in Calif., I do know that the 4 liters like a 40 wt oil, so I would suggest with the miles you have using an HDDO, (Heavy Duty Diesel Oil) in a 15W-40. Dello 400 is a great oil. Also a Hydrocracked petrolium oil that has a lot of bang for the buck. This is requested if you have taken care of this vehicle, and changed oil regularly, (Which it appears you probably did) If there is major sludge build-up, the HDDOs will soften the deposits and could cause problems. If you feel it is a clean engine, you will be fine. You could go easily 5,000 miles between changes with this oil, and as much as 7,500 if most of your driving is highway.<br /><br />If you have been using a 10W-30 oil, you may notice a very slight loss in fuel economy, minor at best though.<br /><br />Watch it for the first 1,000 miles, and if it seems to get dirty very fast, change it at 2,000. Its going to clean your engine as you drive even if you think it is clean.
LubeDude
Originally posted by beezee28:<br /> Can someone tell me if it is a good idea to use synthetic oil on my old car. It is a Dodge Neon and has about 110,000 on her. I read somewhere once and it says that with so many mileage it would not be a good idea. Pls advise. Thanks
Sorry, I got busy.<br /><br />This is entirely up to you, I have seen it go both ways, If your engine is well maintained, you should be fine, I changed my Ford Ranger over at over 100,000 miles and had no problems at all, if you have any leeks now, they will be worse with synthetics, if it is a seal leaking and it isnt cracked, the leak should stop durring the first oil change. Esters have a way of softening seals and helping them seal better after a short tirm. If it is a gasket, it will get worse and stay worse. Just get it fixed like you should anyway.<br /><br />What is your reason for possably wanting to change?
walleyehed
so I should have went longer than a 1000 before changing my mind due to leaks?????<br />Let me know, LD.
TheOilDoc
Posted by LubeDude:<br /><br />Except that Castrols base stock is a group 3, (Hydrocracked petrolium) Good oil, but not a synthetic.
It is a synthetic.<br /><br />The Council of Better Business Bureau's National Advertising Division (NAD) ruled that "synthetic" is a marketing term. The ruling spells out that it is the responsibility of the marketer who is labeling the oil to define what it is.<br /><br />The Society of Automotive Engineers (SAE) removed all definitions of "synthetic" from their specifications relating to oils.<br /><br />The American Petroleum Institute (API) does not define what a "synthetic" is.<br /><br />Synthetics from highly refined group III base stocks perform similarly to other types of synthetics. They far exceed most engine requirements and cost much less. Consumers demand them because they can get the basic performance of a synthetic without the cost of a group IV or V base oil. For many engine owners it makes more sense to spend a third less money (over oils like Amsoil) for more than enough engine protection.<br /><br />Member LubeDude, you are defining "synthetic" only in Amsoil's terms. Like most oil marketers, Amsoil believes their synthetic is the "best" and all others should follow. They have gone to great extent to convince potential buyers and distributors of their product the same.<br /><br />
Posted by LubeDude:<br /><br />Other than the amount of Phosphorus isn’t that big of a deal though. Amsoil just feels that it isn that bad on the converters as they try and make people think it is.
Unfortunately Amsoil hasn't convinced anyone of that. Amsoil still can not get their high-phosphorus oil API certified. They have not convinced the oil and additive industries, vehicle and engine manufacturers like Ford, GM, Daimler-Chrysler, the Japan Automobile Manufacturers Association, or the Engine Manufacturers Association. They have not convinced the technical societies and trade associations such as the American Society for Testing and Materials (ASTM), Society for Automotive Engineers (SAE), and American Chemistry Council (ACC).<br /><br />
Posted by LubeDude:<br /><br />"Genuine PAO Formulated Synthetic<br />AMSOIL INC. has been the leader in synthetic motor oil formulation since its introduction of the world’s first API rated synthetic motor oil in 1972. By specializing exclusively in synthetic lubricant technology, AMSOIL is able to optimize the most advanced chemistries available. The “Genuine Synthetic PAO Formulated” designation displayed on AMSOIL motor oil packaging indicates that the oils are formulated with Polyalphaolefin (PAO) synthetic base stocks. <br /><br />This chemistry is the industry’s premier base stock technology. Unlike conventional mineral-based chemistries, AMSOIL PAO base stocks contain fully saturated, hydrogenated molecules and are free of wax and other impurities. Combined with an exact balance of premium additives, it delivers superior hot and cold temperature performance, resists oxidation and acid formation and provides long-term wear protection. AMSOIL “Genuine Synthetic PAO Formulated” oils have shattered the parameters of the most rigorous industry testing and set the standard for all other motor oils."
That is Amsoil's exact word-for-word sales statement. <br /><br />We really have no idea what quality or type of base stocks Amsoil uses, or how much PAO is in their oils. There is no indication of what makes their synthetic PAO oil any different from other synthetic PAO oils.<br /><br />
Posted by LubeDude:<br /><br />AMSOIL INC. has been the leader in synthetic motor oil formulation since its introduction of the world’s first API rated synthetic motor oil in 1972.
Drew Chemical Corporation, in conjunction with Mobil Chemical, developed and patented the first polyol ester synthetics in 1958. Mobil Oil's Jet Engine Oil II was based on the fluids produced at Drew Chemical. <br /><br />The first "synthetic" was actually synthesized by C. Friedler and J.M. Crafts in 1877. Standard Oil synthesized hydrocarbons in 1929. The first polyalphaolefins (PAO's) were synthesized in 1937. A lot of development went on in the 40's and 50's by several companies. In 1968 the U.S. Army developed the MIL-L-46167 specification, which was only satisfied with a PAO synthetic oil. In 1972 AMSOIL was formed. They re-labeled the MIL specification oils and marketed them to the motoring public through a multi-level "pyramid" type organization.
JasonB
Heinz, I'll toss in my $.02 to your question. I switched my '92 Ford Ranger 3.0v6 over from 5w30Pennzoil at 110k. not sure what was run in it the first 42k, but I changed it every 3k like clockwork. At 80k she started using oil at about a quart every 3k. At 110k, I went with some Mobil 1 5w30. Oil use dropped. (BTW this level of oil consumption seems to be extremely common on the 3.0 with miles). After a couple changes at 3k, I went with Mobil 1 10w30 and oil use dropped a bit more. I generally lose 1qt every 5k miles now at 163k miles. The first couple changer were nasty by 3k. The engine still runs like a top and gets 22-24mpg in mixed city/hwy. The EPA spec for this truck was 20-25mpg. I think with an older vehicle, it is a gamble. Conventional is the safe route, and at the mileage you have, it must like what you are feeding it.If you have no oil use currently and the enginehas been cared for, you might be ok. You could also take the approach that if the gunk in there is keeping things in check and cleaning it out will cause problems, you may have problems waiting for when you least expect it. You may slowly uncover something as the synthetic cleans her out before it fails suddenly when the gunk comes loose some day. Just a thought that will probably be disproven.<br /><br />That 4.0 is like my 3.0. It's a great motor that is a well designed durable horse that will live a long life if maintained. Mine has lost some umph, but I rode her hard for a few years so it is likely my fault. I still expect 200-250k before major overhaul.<br /><br />The oil guys maye cringe at this, but I am loyal to neither M1 or Castrol. I think they are both fine products. Is the M1 better....maybe, but doesn't matter to me. I change oil in all my vehicles at a 5k interval. Overdoing it I know, but my vehicles fit the hard service moniker. With 5k or less intervals, most quality oils would be good. I tend to buy which of the two mentioned synthetics is on sale in the weeks before my oil change. Currently stocked on Castrol Syntec.<br /><br />My last car had a ford 2.3 of 1986 vintage. I fed it a steady diet of 5qts castrol GTX dino and a filter every 3k. I beat the snot out of that motor as a teenager. There were more 100+mph jaunts than I care to count. I sold that car with 165k miles and it stioll started with the first turn of the key, and if I kkept the leaky tranny full, it still got 30+mpg. It's all about maintenance.<br /><br />I do not, however, run synthetic in the 302 V8 in my boat. tried it. Changed back. the synthetic was a bity thin and did things with the oil pressure via my hi-volume pump that I didn't like.
LubeDude
All I said was that Amsoil was the "first to introduce and API rated synthetic", and it was, I dont care how much research was done by other manufactures, Amsoil released an API Certified 100% Synthetic oil first, Period, end of discussion!!!<br /><br />And, you and everyone else can say that a group 3 oil is a synthetic, but I say if it isnt a group 5 then it is a want-a-be synthetic and made fron petrolium oil. Want-a-be, want-a-be, want-a-be!!!! Plus Castrol sells there Syntech for the same price as a "Real" synthetic. There Bad! Like I said before, if you want a group three, buy Walmarts Synthetic for about $2.00 a quart less.
TheOilDoc
No cringe from me. Some here are very partial to certain oils, claiming theirs is the "best" and finding fault with others. But really the API has taken the guess work out of worrying about what oil to use. Meeting the vehicle's oil specification and maintaining it are what's important. I have absolutely no problem using a bargin sale oil if it meets the spec. And I used to test oils for a living. Both the Mobil and Castrol are excellent oils.
ob
Originally posted by TheOilDoc:<br /> Both the Mobil and Castrol are excellent oils.
What is your opinion on the quality of Amsoil as compared with these two mentioned?Have you ever conducted any tests on Amsoil?
LubeDude
Its not a real oil, its not API Rated so it doesnt count. Truth is that it will beat any oil hands down any way you want to test it.
TheOilDoc
I believe you're repeating what I've already said in my first post: "Many years later Amsoil followed and simply marketed their synthetic to the public first."<br /><br />The importance of who marketed an oil first is irrellevant today, 2005. It is the history behind synthetic invention and development that is facinating. Amsoil had little to do with that.<br /><br />Amsoil uses the illusion that being "first" is somehow identified with quality, superiority, value, and performance. As with any product marketed, that is simply not true. Member LubeDude's statement that other oils are still "catching up" is example of that.<br /><br /><br />
Per legal ruling, that is exactly what the oil industry does. It's the way it is.<br /><br /><br />
Please check your grouping. Group IV is the PAO base stock. Group V are esters. <br /><br />Amsoil consists mostly of group IV PAO's along with a very small percentage of group V esters.<br /><br />I will reiterate once more that oil grouping is used for interchangeability and read-across formulation. It is not a performance measurement.<br /><br />Group III synthetic oils are fine oils. Because an oil is highly refined from a petroleum base does not make it inferior. There are benefits to a petroleum based oil.
LubeDude
So, you see that I never said it wasnt a good oil!<br /><br /> Amsoil uses the illusion that being "first" is somehow identified with quality, superiority, value, and performance. <br /><br />Not at all, I just wanted to make a point that it was the first to "market" an API Synthetic oil, It did after all take a lot of guts to do what Al Amatuzio did back then. It was better then, and still is, Prove me wrong If you can.<br /><br /> Please check your grouping. Group IV is the PAO base stock. Group V are esters. <br /><br />Sorry, I got a little over Zelous! This is true.
TheOilDoc
Amsoil is a fine oil, as most PAO oils are. But there is nothing special about it.<br /><br />As an oil professional I do question quality and consistency of Amsoil.<br /><br />The API uses consistent professional industry standards, controlled testing, unbiased third-parting checks and balances, and a quality control enforcement program for all the oils they certify. <br /><br />Amsoil does their own thing. They pay people to test their own oils and they interpret and provide their own results. They only say they meet the specs. Consumers have to totally rely on marketing's word. Amsoil is one of the few oils that can not become API licensed because it does not meet the API standards.<br /><br />I have not personally tested Amsoil motor oil in a laboratory. My experience with Amsoil comes strictly from using it for years in my own vehicles. I stopped using it because it did not live up to claims of improved mileage, better performance, cost savings, or less wear, etc. In fact in many cases petroleum oil was better. For the cost, Amsoil did not make sense. Other less expensive oils performed as well or better.<br /><br />
Member LubeDude I understand that you sell Amsoil and you are very passionate about your brand. But what exactly do you mean by "beat any oil hands down"? Do you mean price, availability, performance, protection, etc? Please explain. For example what makes it better than Synlube, Redline, Royal Purple, or Mobil, and why? I would like your words, not Amsoil's. Thank you.
TheOilDoc
It is not "better" for many consumers. <br /><br />It does not meet the API specification (warranty) for most vehicles. It is extremely expensive. It is not readily available. It provides no better mileage, performance, and engine protection than other less expensive 100% synthetic oils that are API certified.
ob
Originally posted by TheOilDoc:<br /> Amsoil is one of the few oils that can not become API licensed because it does not meet the API standards.
I Appreciate your feedback.Can you answer one other question?Does Amsoil not meet the API standards because the company will not subject its oil to the testing standards or because it won't pass the standards?Thanks.
LubeDude
Originally posted by ob:<br />Does Amsoil not meet the API standards because the company will not subject its oil to the testing standards or because it won't pass the standards?Thanks.
Several of Amsoils oils in fact are API Certified, I dont have the information as to which ones here with me at the time, but the reason isnt that they are not good oils, Its because your government and manufactures have decided that certain chemicals such as phosphorus can only be at a certain level for certain reasons. Amsoil wouldnt meet those standards as they believe they should be there for the extended drain intervals. There feelings is that Phosphorus isnt a problem with a healthy converter and will not kill one with the amount they actually use. This is the reason that the new oils are not a good choice for older flat tappet cammed vehicles. They have lowered the amount of certain Additives that are essential for these to servive, like ZDDP and phosphorus and why I reccomend an HDDO for these older vehicles.<br /><br />My reson for using Amsoil has allways been only if you are going to extend your drain intervals, At this point, it is the "ONLY" oil that is actually designed for this purpose.
kenimpzoom
I work in the upstream oilfield business and I can tell you what the EPA classifies base oils as.<br /><br />The EPA defines conventional oils as those that come from crude and are simply processed / distilled. Hydrocracked crude is not a synthetic according to the EPA. Mineral oils, paraffins, etc.<br /><br />Synthetics are those that are "made" by some chemical process. IOs, LAOs, PAOs, etc.<br /><br /><br />Ken
LubeDude
Originally posted by KenImpZoom:<br /> The EPA defines conventional oils as those that come from crude and are simply processed / distilled. Hydrocracked crude is not a synthetic according to the EPA. Mineral oils, paraffins, etc.<br /><br />Synthetics are those that are "made" by some chemical process. IOs, LAOs, PAOs, etc.<br /><br /><br />Ken
My sentiments exactly. And, like I have said before, Hydrocracked oils are "very" good oils, but they shouldnt be able to charge the same price as the "Real" Synthetic oils.
Realgun
I just run the oil of the correct weight, in my case 5w-20 for 5000 miles then I change it.<br /><br />We have a ford van with a 4.2L V-6 that gets run every day at 85-90 mph and gets an oil change every so often about 10-14000 miles. It does use oil so about 3 quarts are added between changes. It runs well and does NOT smoke and passed emisions last month. This Van just turned 200,000 miles and is 5 years old. It gets 5w-20 penzoil.
TheOilDoc
Posted by KenImpZoom:<br /><br />I work in the upstream oilfield business and I can tell you what the EPA classifies base oils as. The EPA defines conventional oils as those that come from crude and are simply processed / distilled. Hydrocracked crude is not a synthetic according to the EPA. Mineral oils, paraffins, etc. Synthetics are those that are "made" by some chemical process. IOs, LAOs, PAOs, etc.
The EPA oil definitions you mention can be found in 40CFR435. But they refer to drilling oils that are used with drill machinery to extract oil and gas from the ground. Not much to do with motor oil. <br /><br />Drilling oils have an environmental impact when in direct contact with soil or water (usually in the form of drill cuttings). Synthetics react differently than petroleum oils when in contact with the environment and they produce a different biodegradation rate ratio. The EPA has established drilling oil definitions so their environmental regulations could be followed clearly by oil drilling companies.<br /><br />Actually, the Clean Water Act, Section 311(a)(1) defines "oil" as, "oil in any kind or in any form including, but not limited to, petroleum, fuel oil, sludge, oil refuse, and oil mixed with wastes other than dredged spoil." According to the EPA, they have interpreted this definition to include crude oil, petroleum and petroleum-refined products, as well as non-petroleum oils such as synthetics, vegetable, and animal oils.<br /><br />But it doesn't matter what the EPA classifies oils as. The EPA has no regulation on motor oil makers. Believe it or not, oil companies could bottle anything and sell it as motor oil. Thus we have the API to standardize oils and ensure consumer confidence. <br /><br />The EPA is only concerned with emissions that the engine produces (using whatever oil/substance the auto manufacturer recommends). They are also concerned with environmental impacts when the oil is extracted from the ground (ie: the use of drilling oil) and how oil is disposed of as used oil (the EPA defines "used oil" as any synthetic or petroleum oil).<br /><br />Mobil used the EPA's definition of drilling oils as argument in the Castrol "synthetic" case. It did not work. The EPA definitions have absolutely nothing to do with manufacturing automotive oil.<br /><br />The problem with defining "synthetic" is that it would limit synthetic oil to one formula, and probably one brand. No synthetic oil contains 100% synthetic oil. There are additives, etc. Each synthetic formula is different, and everyone's interpretation of what is "best" is different. Some oil makers could simply put .0001% "synthetic" in their petroleum oil and call it "synthetic" oil, while others use 75% group IV PAO.<br /><br />Clearly there is a reason why the courts did not want to define "synthetic". There is no reason why a "synthetic" oil maker can't label his oil with exactly what's in it. And there is no reason consumers can't think for themselves. <br /><br /><br />
Posted by LubeDude:<br /><br />Several of Amsoils oils in fact are API Certified
According to the API, of all the Amsoil oils only the lesser XL-7500 and the semi-synthetic blend are certified.<br /><br />
Posted by LubeDude:<br /><br />Amsoil wouldnt meet those standards as they believe they should be there for the extended drain intervals.
Two problems. First, not everyone uses Amsoil as an extended drain oil. Without the extended drains the Phosphorus does not deplete. It compounds the problem. Second, most automobile engine makers do not recommend extended drain intervals. You can actually void your warranty doing that.<br /><br />
Posted by LubeDude:<br /><br />There feelings is that Phosphorus isnt a problem with a healthy converter and will not kill one with the amount they actually use.
The people who designed the emission system and supply the warranty do not agree. Testing supports their stand.<br /><br />
Posted by LubeDude:<br /><br />They have lowered the amount of certain Additives that are essential for these to servive, like ZDDP and phosphorus and why I reccomend an HDDO for these older vehicles.
Modern oils are loaded with wear additives, and they will protect a flat tappet engine better than the oil the engine was originally designed to use. Heavy duty diesel oils (HDDO) meet the same API's phosphorus standards as non-diesel oils.<br /><br />
Posted by LubeDude:<br /><br />My reson for using Amsoil has allways been only if you are going to extend your drain intervals
Most engine manufacturers do not recommend extending drain intervals. They designed the engine.<br /><br />
Posted by LubeDude:<br /><br />At this point, it is the "ONLY" oil that is actually designed for this purpose.
Incorrect.<br /><br />Oils like Royal Purple advertise extended drains. Other oils like Mobil are ok for extended drains, but recommend following the manufacturer's change interval for warranty purposes. Oil sampling and testing have shown that even inexpensive petroleum oils can be used for extended change intervals, especially when using the bypass filtration and top-off oil like Amsoil recommends.<br /><br />Member LubeDude, Amsoil is a fine synthetic oil. Castrol is a fine synthetic oil. Guess which one has the higher markup on price.
