Old 454 head won't come off- Help
old bird
I pulled everything down ,to the pull the head.
Now i can't get it to break loose from the block. It's a 1977, 454, 330hp,
any ideas what i should try to do.
i put some pretty good pressur on it but don't want to break somethin
so i covered her up and came here for some help
Thanks, Larry
Re: Old 454 head won't come off- Help
Thanks, Larry
Ayuh,... Even though yer no doubt Sure, recheck to make sure you pulled ALL the head bolts...
Then gently pry up on the center most corners, fore, 'n aft...
Where the head overhangs the lifter valley...
count how many bolts you removed on that head. Should be 16
old bird
Thanks so much, I knew you guys would help.
i'll count the bolts. yes, i checked and checked, thout i got em all.
i pryed and pryed, i'm old, but thought i could still break loose a head.
Hope i don't need too much more help, Thanks Larry
