Old line for live well now a big hole in hull
capndan
my '89 Crestliner used to have a livewell. Today I took the boat out and the bilge was running, as if I had no plug in it. When I got the boat back on the lift, water was flowing out of hole that used to have a flow through fitting, but is now mysteriously gone. I don't use a livewell on this boat. I just want this hole plugged up. I can see where the fitting used to be because it's a place in the hull where the years of surface stain are not there, like a tan line. It must have just happened because I have been using the boat all summer.
The diameter of the hole is 1".....I am looking for a piece of hardware to plug this hole up. It also looks to me like there is another similar fitting that hasn't fallen off yet, which I would also like to replace at the same time.
Thanks.
the plastic thru-hull fittings have about a 15 year life expectancy, just like the plumbing on most livewells.
get a new thru-hull fitting. seal it, then cap the end. and in 15 years, if you still have the boat, replace it.
Where did that figure come from? Past experience puts the figure for nylon fittings closer to 5-6 years.
My boat was not quite 5 years old when I bought it. Upon closer inspection, I found 7 out of 12 thru hulls where cracked. Needless to say I replaced every thru hull and both scuppers with stainless
Concerned with what I found, I wrote an article in our club newsletters letting people know what I found with the recommendation to inspect their thru hulls. The number of positive responses I received was alarming.....
https://www.practical-sailor.com/issues/37_78/features/Plastic-Through-hull-Warning_12215-1.html
YMMV.... approximate rule of thumb based on an article in plastics engineering from a few years ago. however age / temperature / UV / /hose support / etc. will all degrade the plastic used thru-hull fittings.
you have aging of material based on time
you have temperature aging of material causing embrittlement
you have photo-chemical degradation from UV and Ozone
you have material fatigue from flexure.
the consensus....plastic sucks
Given the threat of life from a thru hull failure, you would figure life expectancy would be based on the worst, not best case scenario.
Then again, its a trade magazine....
I agree, plastic suxs
