old mercury
delanesr
i have a 60 something 110 mercury had forever been kind of wanting to go through and rebuild just because never done it . med mechanic skills am i looking for trouble or is it fesiable
Nordin
Look for trouble at this one, old Merc.s did not have stainless steel drive shafts.
Maybe the drive shaft has rusted in the crank shaft splines.
If a saltwater engine most bolts and nuts are corroded.
BUT check it out first and if a no saltwater engine it is rebuildable.
Old Merc.s are really nice engines.
Good luck
1960 Starflite
I've a 1960 (300), 1965 (650) and 1975 (850). All have been good engines. The 300 and 650 have a magnito, which points are hard to find and expensive. The 850 has a distributor and switch box. Again expensive ignition parts if you can find them. Carburator parts (floats, gaskets, needle n seats) are available. Fuel pump parts also available.
Rebuilt a mid 60's 4 cylinder 65 HP on behalf of a dealer last winter.----Parts are not that hard to find.----A lot depends on your location.
