OMC 2.3 Converting to Electronic Ignition
Bulbash
Guys, got tired of screwing around with points. Went ahead and purchased an ignition conversion kit by Sierra. Installation does not look complicated, but would I need to upgrade my ESA module? Or can I run with the original?
Lou C
Yes you have to replace it with one that will work with the electronic ignition.CDI electronics may have what you need...
Or you can fabricate this simple circuit that will allow it to work at a cost of a few dollars. A new ESA module is rather expensive. In fact, I did two of these last year and can send you the resistors and diodes on me if you like. I have a bunch of extras.
A very helpful member here turned me on to this last season. He used pins and plugs for connections. I soldered and heat shrink tubed mine. Have a look:
You're essentially putting the circuit inline in the gray wire and connecting it to a ground.
The Sierra unit that you bought is actually a Pertronics unit and they will honor the warranty as well as provide tech support if needed.
