OMC Carb Overflow Tube
kpg7121
Engine is a 1987 3.0 & I need to replace the overflow tube from the carb to fuel pump. I checked a few websites for the tube & it appears to be NLA. Anyone know what the diamater of this tube is? The reason I ask is that the tube appears to be flared where it goes over the fittings. Is that the case? Thanks.
kenny nunez
Over flow tube.
The tubing is Tygon and you should be able to obtain a replacement at a lawnmower repair shop. Actually any fuel resistant hose will also work. I think it is 1/8 “ inside diameter.
Ayuh,....... I think 1/4" id, but you maybe right Kenny,....
No flare on the tubin', it stretches over the barbs,..... warm it if necessary,....
