omc cobra service manual
fendersfender
Does anybody have a link for omc cobra service manual? I see that merc manuals can be downloaded. thank you
havasuboatman
Ensign
Re: omc cobra service manual
Did you look under "OMC information"? There are links there for some OMC manuels.
MRS
If you go on e-bay you can buy the manual for the year you need. Just make sure you buy the omc cobra manual and not a off brand. I also bought the parts and options manuals for omc they have all the part numbers so when you are looking for parts you will have the right numbers for your year and engine size......
MRS
Probably don't need this. Depending on the year, most of the part numbers have changed and you can get the exact info online.
Yes the numbers have changed but they will tell you what they were and what they changed to. Helps when you know the original numbers and have two or three different part numbers for the same part of different models helps me anyway......
Online tells you what they were and the new number.
