OMC Stringer Exhaust Manifold
72IMPAZTEC
Hello,
I'm not sure this is the right place to post this, but here goes.
I need an exhaust manifold for a 1972 OMC stringer.
Finally got the boat together, went to the lake, boat was running great. Then BANG......pop pop pop....etc. etc. other loud noises.....
Manifold cracked. Welder said it can't be welded, it is too thin.
So, anyone got one laying around? Have checked E-bay, no luck so far.
Any ideas? Links to sites that list used parts?
Thanks in advance,
Jon
Manipulator
Re: OMC Stringer Exhaust Manifold
Would help if we knew what motor you are talking about.
Ayuh,.........
Believe it or Not,...........
There was atleast Several Different Motors used with Stringer drives in 1972........
And,..... Of Course,.......
They All used Different Manifolds.............
72IMPAZTEC
Well......goodness..
Thought you guys were smarter than that....:rolleyes:
Sorry.:redface:
307 Chevrolet
The manifold, looks like it is the same from side to side, has some "caps" that bolt to each end, seems like it would reverse if you swaped them end to end?
Thanks again
