OMC Thermostat housing/thermostat replacement
[OBC]Patch
001.jpg88 bayliner capri, 5.7, cobra. The engine thermostat is deep inside the thermostat housing, and it appears inaccesible. How do I replace it?
thanks.
Patch
Lou C
Re: OMC Thermostat housing/thermostat replacement
dig out the rust and you will find a rubber ring holding the thermo in place...it fits into a groove in the thermo housing, pry it out with a small screwdriver....spray that mess with PB Blaster or Kroil and let it sit for a while first.....salt water eh?
Summer Fun
Banned
Throw that housing in the trash !!. :eek: and get a new one. :)
[OBC]Patch
ok, I'll dig for the O ring like I know what I'm doing..;) Then I'll dip it in acid, repaint it and spend the $100 on gas! :D
Thanks!
