omc water in lower unit
jch7450
I have a cobra I replaced the impeller this year.can you tell me if the seals arn;t right,will it or could pump water in the lower unit? last year my lower oil was clear as a bell,thanks, joe
Re: omc water in lower unit
Yes, It's Possible........<br />As stated on another post,(You could have continued your other thread, instead of starting a new 1 about the same Problem)<br /><br />A Pressure/Vaccum Test will tell you Exactly Which Seal is Bad......... ;)
jch7450
Thanks alot BONDO....one thing...can the seal behind the prop be replaced without tearing the lower unit down.....thanks again! joe
Sorry Joe.......<br /><br />I Don't Do OMCs........<br /><br />I'm sure that 1 of the Guys Can help, But, I Can't.......
