Oops! 97 120 is always in forward
scottnjay
I just screwed my engine up more than when I started. I was putting in a new impeller and when I finished and tried it out on the muffs The prop was spinning even in neutral. I must have accidently spun the shift spline. The prop also makes a ratching sound when spun forward, but is solid when I try to spin it in reverse. This happens in all gears. DOes anyone have any idea how to fix this. I don't want to have to drop the lower unit over and over since it is getting heavy. Is nuetral in the center of the rotation of the spline shaft. It seems to go a little over 180 degrees in rotation. Please help me. My wife is a little miffed about me buying a used boat and already having to work on it.
Re: Oops! 97 120 is always in forward
Your wife is right, you should have let her buy you a new boat!! :) <br /><br />You should put the motor into forward gear before you drop the lower unit on your motor, and put the lower unit in forward before re-assembly.<br /><br />For now, drop the lower unit.<br />Shift the controls into forward.<br />THen turn the shift shaft one way or the other.<br />When forward gear is engaged and the propeller shaft is turned clockwise, the clutchdog will "ratchet".<br />THen slide the lower unit on.<br /><br />Then go hat in hand and tell your wife she was right, and that you will let her buy you a NEW boat now.<br /><br />Good Luck and happy boating.
scottnjay
Roscoe, thanks for the help. I did have it in forward when I removed it, but I must have turned it a little before I reassembled. Now the problem I have is that when I look at the spline shaft it only turnes about 1/4 turn between forward and reverse so finding the point 1/8 turn from forward is tough. The prop ratchets no matter which direction I turn the gear shift spline so finding nuetral is tough. Do I have to keep lowering the unit and indexing the shift shaft until i find it or is there an easier way? <br />New boat would have been nice, but paying for it would have killed me before I got to enjoy it.
