Opinion on crank journal..
rk970
Journal is smooth and mics on specs, not oval or tapered.. Is this ok to use?
GA_Boater
What is the crank out of. Plain or roller bearings?
rk970
125hp 4cyl force outboard, 2cycle cross flow, roller bearings
1258X5A
Nordin
Not 100% okey but I should go for it if you do not have put a lot of money in it.
If you have rebore and put in new pistons ...... look for a better used crank.
I would not be satisfied with that crank with a rebored block and new pistons.
rk970
I decided to try to find a better crank.. The force 125 crank part #FA528018 has been superseded to part # 817400T3
I found a local crank from a 1992 force 120, when I looked up the part number for the crank it is 817400T3. I cannot confirm anywhere if the stroke on a 1992 120 is indeed 2.875". I went and looked at the crank its in perfect condition with all bearings and he is asking $60 for it..
Can some one confirm what the bore/stroke on the 1992 120hp are, it is a 15 spline crank and it has the force lower unit.
jerryjerry05
You'll need to get the factory manual to find the stroke.
​IF??? my memory is right 1992 they used 2 different size pistons.
The crank can be used on 1990-1994 model blocks.
I would bet the 90's crank is the 2.875
The manuals I have show the 86 is 2.80 and everything in the 90's is the 2.875
​BUT!! I don't have a manual for the 90's 120.
​I'm comparing a manual for a 86/125 and a 90's 150.
​The old crank: does it catch a fingernail in the holes when you touch it?
​From the look?? If it doesn't have ridges on the holes? It should be ok to use.
rk970
I measured the stroke on my 1985 125hp (1258x5a) at 2.87* I have a 908h4b (84 4cyl 90hp) and that stroke measured at 2.80*.
I cleaned the rod journal and main with 800, then looked at it under 20x magnification. There are a lot of pits, some areas I can feel "catch" with a finger nail.. Some areas between the pits have what look like micro fracturing of the surface. The rollers and bearing shell from that main have the same appearance.
I have done some mild porting on the transfer ports and a new set of pistons going in. I just got a bad gut feeling on running this crankshaft..
kbh121956
I would go by your "gut feelings" And try to find another crank.
jerryjerry05
Now the tough part, trying to remember that!!
​I can remember pretty much everything I did up until I hit 55 .
​Now!! I can't remember what I had for breakfast!!!! :)
