Opinions on questionable catamaran hull design
madman2021
I am currently looking at purchasing a new offshore boat and a very unique catamaran caught my eye. this is a boat built in 2004 with plans purchased from a company who builds these boats. the boat is 34x12 and is made of aluminum. the hull bottom is 3/16, the sides and cabin 1/8, and the rest of the boat consists of a mix of 1/8 and 3/16. the ribs, stringers and all framing are 1/4 plate. it's a very odd hull design with very shallow hulls. shallow enough for the area between each hull to sit in the water 2-4 inches while at rest. just by looking at these pictures would you think this would be a boat that pounds and sneezes a lot? my main use of this boat would be to fish a lot of people both insHore and offshore. the owners of the boat used it very little aND mainly for inshore fishing so the feedback isn't very accurate.
shaw520
"Pound and sneeze a lot"?.... I would say yes,.. I cant see it being good for more than a 2-3ft chop.
Watermann
It all depends on what you're plans are for the boat and where you're going to use it. I don't know what sneezing means in regards to boat hulls but all of them will pound you at some point if you don't understand slowing down makes it stop the pounding.
The owner sure has an odd fascination with horses. :lol:
fetch
shaw520
fetch
Im sure you've seen flat bottom boats in chop,.. particularly a cat hull,.. when the chop reaches the height of hull they tend to "sneeze" water back out the front,.. it makes for a lot of spray over the bow.
southkogs
Tri-hulls can do that to you too. I've never been on a cat in big water though - and I've never had a tri blow back enough water to come over the bow. I've got no clue how that boat would do ... those lifting "fins" on the sponsons are kinda' nifty. I wonder how high she comes outta' the water?
Can you get a test run in it?
H20Rat
That boat draws a lot more than 2-4 inches! From the looks of it, it nearly sunk! Check out the water line. In particular, this picture is interesting. The back starboard corner probably spent time underwater. Given the fact of the uneven waterline, I'd be highly suspicious the boat didn't have some problem hiding in there.
garbageguy
Interesting? yes. Offshore? don't think so
And the fact it was used seldom, and mainly for inshore - could be cause for concern
southkogs
I think that's what I was seeing with the "fins." Kind of a hydrofoil effect maybe that means it might plane out kinda' shallow ... but she draws a bunch sittin' still.
H20Rat
He was talking about the the span between the hulls drawing 2-4 inches, like you said, the entire thing is in the water at rest, and still sitting low.
Went back and re-read it, yeah he wasn't talking about draft. Still would be concerned, that uneven water line isn't good.
madman2021
Can't get a test run on it. both motors and all electronic controls are junk. I've seen this boat where I fish for 11 years. I've seen it run twice. the numbers I hear are 32-35 cruise and 45-49 mph top with a light load. I'd be interested in a used repower with 350 yamaha outboards. those motors sell cheap around me. there are lots of catamarans up in Alaska with this hull design. mostly work boats. I've read that the reason for the space between both hulls to sit in the water is to provide stability in a quartering sea.
madman2021
I've talked to the owner about that. they had an issue with contaminated fuel on one tank and ran the boat just on the other tank for a little while. hence the reason for the uneven waterline.
southkogs
... there are lots of catamarans up in Alaska with this hull design. mostly work boats. I've read that the reason for the space between both hulls to sit in the water is to provide stability in a quartering sea.
The thing has to have some moxie to it then, huh? I can see the sponsons digging in as a stabilizer - probably running lower speeds though.
