Opti Idle Temp?
Salty Dog
My twin 2001 150 Optis idle at two different temperatures. Port is 159 and Starboard is 120 on the Smartcraft gauges. Which one is normal?
Fun Times
Re: Opti Idle Temp?
The temperatures typically average between 120 & 130 degrees.
Salty Dog
Re: Opti Idle Temp?
Thanks fun times,
I went out today and port between 600 and 1000 rpm temp was 159-170
starboard between 600 and 1000 rpm temp was 132-143
Strange thing is the port side has a little better water pressure
Fun Times
Re: Opti Idle Temp?
Starboard between 600 and 1000 rpm temp was 132-143
The thermostat is rated at 143 degrees.
