orbital or rotary polisher
kyudizky
try to bring back the shine on my boat. got some McGuires oxidation remove and Gel Coat Labs-Oe step gel coat micro polish and sealant. should i use a rotary or random orbital machine to apply each?
Also, on my outboard (black mercury) is is ok to use these products to remove the dullness or should i use something else?
appreciate the help!
geedubcpa
Re: orbital or rotary polisher
As with any polisher - you are removing a thin layer of paint - so don't over do the polish process or you won't have paint. Try a little out on areas that are less likely to be seen.
Rotary. ........... have you used one before????
There is an associated learning curve and it WILL destroy your finish if it is not used properly. It will burn through a finish....... NEVER hold it in one place and always keep it moving.
boomerman
Meguiars Dual Action Polisher G110
They are safe and will not damage your paint.
Bifflefan
With out dancing around the real question,
Rotory is for tough cleaning jobs of removing, whatever.
Orbiting is for polishing after the, whatever is removed.
pluto1
Go to this website and read about how you should clean and polish your gelcoat.Good info on what cleaners and polishes to do the job right the first time.
http://autopia.org/
go to the forums and read about Marine and RV cleaning
