Outboard lifter was struggling.
massimofinance
Today I noticed one of my lifters seemed to be struggling so I took off the anode and saw a few metal seals on the shaft that were slowing the shaft down. Do I need to worry about these? Do I need to replace them? Pictures below. Boat is used in saltwater. Thanks.
flashback
I think the ram needs replacement or rebuilding. It's not helping the effort and just along for the ride.. IMHO
If you have water in the fluid, your cylinders will be corroding from the inside
The partial seal and keeper pictured stuck on the ram indicate an end cap/seal replacement at a minimum. Agree with others there may be more issues not yet obvious
If you primarily operate the boat in saltwater you should be using zinc anodes only. Aluminum will only help halfway, magnesium will do little/nothing
massimofinance
Wanted to circle back up here. After de winterizing the boat last week the rams continue to struggle. The switch doesn’t work right away and when it does, the rams really struggle. I have to lower the trim all the way to raise it at all. Getting two replacement rams and will swap them in next week. Will close the loop with the forum after. Thanks.
