outdrive gasket set installation tip please
caddylover
This will be the first time for me putting the drive back on, so how does one keep the larger flat seal in place when installing? I will be using bellows adhesive for the water hose o-ring to keep that in place, but for the larger seal what does everyone use?
Also, the large 0 ring seal that goes with the ujoint bellows.....does that need adhesive also or is it just press it into the hole against the bellows ring retainer and you're good to go?
Re: outdrive gasket set installation tip please
Nothing on the gasket, bellows adhesive works great for the water passage oring and the large quad ring in the bellhousing.
MarkSee
I use a few small dabs of bellows adhesive on all the gaskets to help hold them in place when installing the drive for the first couple of times.
You might also want to see if you can find the shift slide installation tool, 91-865232, that only costs a couple bucks and helps with the installation.
Mark
Ayuh,.... Welcome Aboard,... The flat gasket is hung on 6 studs,... it ain't goin' no where....
I use a gob of Grease on the o-rings with Good luck,...
Yer results may vary....
smoedog
just lube up the seals with vasoline and stick them on. its what we use in the AF
achris
More fish than mountain goat
The large square section rubber ring (goes inside the bell housing) should be glued in with bellows adhesive...
