Outdrive only moves prop at low rpms
jc turtle
1988 4 Winns 350 omc . Engine revved up quickly while at about 3000 rpms, then would only move boat at low rpms.
I would presume that the coupler let go, but anything else it could be? Verifying that I won't pull the motor for the
wrong problem. Thank you, John
Redrig
Engine coupler or a spun prop hub I would have to think
Agree, coupler most likely. If you smelled burnt rubber it is the coupler, if not still could be or hub. Mark the prop and hub and take it for short spin
Pull the drive and look thru the gimbal bearing to see what the splines and coupler look like
Stringer or Cobra drive.
with a cobra, could be coupler or prop. Most likely the prop. Draw a line across the prop hub with a sharpie
With a stringer, its not the coupler, however could be the prop. Moast likely its the vertical driveshaft splines have failed (very common issue with OMC stringer drives.
it could also be stripped out ball gears.
