outdrive primer paint
995jim
hello, I have some 2 part epoxy primer for automotive and wonder if this is acceptable to use on my bravo outdrive .
thanks jim
JimS123
Aluminum requires a zinc chromate or acid etching primer. I'm not sure about epoxy. My suggestion would be to contact the manufacturer and see if it is compatible with aluminum.
crazy charlie
Green zinc chromate primer on aluminum.I have also used yellow zinc phosphate primer on aluminum with good results. Never heard of using epoxy primer. Charlie
eggs712
Epoxy primer works, I would etch prior to painting with vinegar.
Agreed epoxy primer Like PPG DP series is great for bare aluminum. Used it in automotive retso applications and has held up for decades
