Engine is Salt Water Only never flushed due to location. It has done 320 hours in 6 years and always been winterised and serviced. Nothing wrong on last outing hits 4800 rpm and 52mph (19ft Regal LSR). Starts fine etc. I have removed it from the boat due to things rusting with the aim to give it an overhaul. I intend to
1) Replace the exhaust manifolds and risers and check valves.
2) Renew any electrical cables / connectors that show signs of corrosion. Ensure that all connections are good and rust free then coat with liquid tape (Like Neoprene dip).
3) Replace front engine mounts due to corroded nuts, no adjustment possible.
4) Paint the engine.
5) Replace Starter motor (Old solenoid failed , unit rusty).
I have already replaced the impellor , belts , rotor , dist cap , ignition leads, coil and shift cable last year. What else should I be looking at doing? What is sensible to do on an engine this old?
Any tips appreciated.
Regards
Chris
P.S Thanks for the help on the engine removal thread it all worked!
Regards
Chris
