switzer140
- Joined
- May 29, 2013
- Messages
- 35
Engine is a 1978 evinrude 140. So today i was out on the lake with the family, we were running around for about 20 min or so and the overheat alarm came on. i shut it down immediately and we sat around for a quite a while. after about 30 min we started it up and headed to the dock which was about 100 yrds from where we were sitting so had it running for less than a min back to the dock, but it was hot. Hoping i did not damage the engine. I did notice driving back to the dock there was no water coming out of the pee hole like usual. At the beginning of the season i installed a new impeller pump and have had it out at least a dozen times since, have never had a problem cooling until today. I did have an issue with what seemed like the carbs possibly flooding and i rebuilt them about 2 weeks ago. when i took the carbs apart everything suprisingly looked great like new inside, however i went ahead and put the rebuild parts inside. last weekend i thought it did perform better and the engine seemed to run smoother. however at the end of the day it seemed like there was surge temporarily so i took it to the dock and put it away until today. Dont think it has anything to do with the cooling issue but any idea where i should start to figure out what is going on?
