Overheating: Water coming from outdrive
fishingdan
I have been troubleshooting an overheating problem. Occurs at idle as well as running (naturally).
Murphy's law has jumped into this a couple of times. For example, while running on muffs recently, I realized that water stopped (or nearly stopped) coming from my hose while I was running the engine. When I looked into the house problem, I saw that my pump pressure switch failed which was causing my reserve tank to run dry. Replaced the impeller - again!
I put everything together and while running on the muffs again, I noticed water coming from the outdrive (see photo). This isn't normal, right? I assume that I missed the water tube somehow when I put the drive back on. The photo isn't my boat obviously, I just used it for illustration. The arrows are showing where I see the water squirting from. Water is still getting up and through the engine, but I not convinced all of it is getting there.
Thoughts?
Bt Doctur
Re: Overheating: Water coming from outdrive
water should not squirt out from there with the mounting gasket installed properly.
fishingdan
thanks bt, but what "mounting gasket"? I suspect something is off or split where the water tube comes up from the waterpump housing.
bigskiohio
your oring fell off or is bad at water port on bell housing.
Dshow
What kind of outdrive do you have? I believe there is an o-ring on the cooling connection between the outdrive and the boat. Is that in place?
fishingdan
I need to look. Sorry for not posting the details. This is a 1991 4.3LX with an alpha one.
