B brogden31 Petty Officer 2nd Class Joined Mar 18, 2007 Messages 103 Aug 8, 2018 #1 I need the part # for the black hose with quick connect end that goes from the t/t pump to the foot .alpha one gen 2
harringtondav Commander Joined May 26, 2018 Messages 2,520 Aug 8, 2018 #2 Please post a pic. As far as I know the trim pump hoses have flare nut connectors. Edit. My '96 Alpha Gen II has Sierra 18-2435 and 18-2436. I gave you the Sierra p/n's because of their equal quality to Merc, and are 2/3 the cost. Check the pic for these two parts and buy the one with your length and gimbal end tube bend. Also but an inexpensive 27-98823 1 gasket while you're at it. Last edited: Aug 8, 2018
B brogden31 Petty Officer 2nd Class Joined Mar 18, 2007 Messages 103 Aug 8, 2018 #3 Ill get a pic but its in a 2006 vip deckliner if it helps
alldodge Moderator Staff member Joined Mar 8, 2009 Messages 43,911 Aug 8, 2018 #4 The quick connects are adapters which fit on the hoses http://www.michiganmotorz.com/mercruiser-trim-pump-quick-connect-adapter-p-11196.html
Fun Times Moderator Staff member Joined May 16, 2009 Messages 9,310 Aug 8, 2018 #5 http://www.mercruiserparts.com/bam/subassembly/30969/11210/140 1- 32-865384001HOSE, Black, Hydraulic Manifold to PumpNotes for Part Number 865384001 Includes parts listed below: FITTING, Female Quick ConnectACT $103.40$90.481
