need the parts break downs for the bearings , cable, and shift bushings for the gimble and transom
J jimmy wise Petty Officer 1st Class Joined Sep 6, 2012 Messages 288 Apr 12, 2014 #1 need the parts break downs for the bearings , cable, and shift bushings for the gimble and transom
alldodge Moderator Staff member Joined Mar 8, 2009 Messages 44,096 Apr 13, 2014 #2 Re: parts breakdown for 898 gimble and transom Have a look here, this is for years 1983-1990 http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=99964
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,494 Apr 13, 2014 #3 Re: parts breakdown for 898 gimble and transom a year and/or engine serial number or engine make would be more helpful
J jimmy wise Petty Officer 1st Class Joined Sep 6, 2012 Messages 288 Apr 13, 2014 #4 Re: parts breakdown for 898 gimble and transom 1980 305 gm side trim sender ....need a whole gasket set and all the bearings for the gimble and transom is this for I boats parts? Last edited: Apr 13, 2014
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,494 Apr 13, 2014 #5 Re: parts breakdown for 898 gimble and transom Trim Sender/Limit Kit for Mercruiser - Sierra 18-7633 all the parts are listed here at iboats.look under the header "mercruiser parts"
J jimmy wise Petty Officer 1st Class Joined Sep 6, 2012 Messages 288 Apr 13, 2014 #6 Re: parts breakdown for 898 gimble and transom I was looking but not seeing the gimble picture......you think sierra parts are ok?
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,494 Apr 13, 2014 #7 Re: parts breakdown for 898 gimble and transom Made in the same place every other manufacturer gets them, I use them. gimbal is on page one of the parts
J jimmy wise Petty Officer 1st Class Joined Sep 6, 2012 Messages 288 Apr 13, 2014 #8 Re: parts breakdown for 898 gimble and transom thanks
