parts for 898 sterndrive
jeepofino
Where can I order a rubber gasket that goes from exhaust elbow and a shift shaft tool for 898 sterndrive alpha 1?
Re: parts for 898 sterndrive
Ayuh,... Right here at iboats Megamall of course,....
Which exhaust boot,..??
What shiftshaft tool,..??
jeepofino
Bondo, it's the exhaust boot between the riser/elbow and the y tube that I need.
Ayuh,... You'll have to Measure the inlets, 'n outlets, as there's a few choices...
Then hit the Megamall, clickin' on the links through the Merc parts listings...
Ya otta be able to figure out which part # is which size....
jeepofino
exhaust elbow rubber boot to y tube
Where can I order the exhaust rubber boot for 898 mercruiser from elbow to y tube? Phone #?
Re: exhaust elbow rubber boot to y tube
Ayuh,... Like I said in This thread you just started,...
You have to Measure the size of the boot...
On Your 898,... Are they 3", or 4",..??
Are they straight, or different sized ends,..??
Are the log manifolds,..??
or center risers,..??
jeepofino
Exaust at the rear of manifold comes out of elbow 3 inches to 4 inches on the y tube............
Merged both posts together. Please do not post multiple times on the same subject.
jeepofino
Sorry, I was just asking for help on finding parts....checked all I knew on the store here but didn't find the rubber boot. I called the phone # here and salesperson couldn't find them either. Didn't mean to get anyone ruffled.
It may not be an aftermarket part stocked by iboats. iboats isn't a Mercruiser dealer.
Best thing you could do when looking for parts, is to first find the correct OEM parts from a site that sells OEM parts, here is one as an example. http://dougrussell.com/partscatalog/collections/index.cfm?fuseaction=collectdetails&colid=04
Once you have found your engine and serial number range, and the correct part number, then you can start looking for aftermarket parts. Just make sure the aftermarket number crosses to the OEM number.
jeepofino
Thankyou Don for that link. I have saved it and will use it in the future. found all I need for the moment. Thanks again, that did it.
