Parts for mercruiser 1 outdrive
gmaster
I am restoring a 66 glassmaster with a mercruiser 1 outdrive. I want to completely go through the outdrive and replace the seals,gimball bearing,bellows,gaskets,shift cable and I will need a gasket that goes between the outdrive and transom , which is the old flat gasket. Does anyone know where I can find these parts . I can probably have the transom gasket made if I cant find one , but I cant seem to find a web site that has the other parts that I need. I looked into changing to a later model outdrive but the bolt pattern is different and I would have to cut and redrill the transom. Since the transom is in good shape I want to stick with the merc 1.Thanks very much for any help. gmaster
Re: Parts for mercruiser 1 outdrive
Ayuh,... It's just minor Trimming,+ drilling a couple more holes,...
By far, the Best idea...
Most of the Mod.1 parts are available right here at iboats mega-mall...
Other can be found from Mercruiser,...
And,...
Some are NLA...
gmaster
I will need gimball bearing,seals,shift cable and a transom gasket. I have a extra mercruiser 160 outdrive. I would need a bell housing,gimball,and transom plate assembly to make it work. I have found these items for $300.00.Do you think this would be a good model to use? Also ,how thick should my transom be on a later model outdrive? Thanks for your help gmaster
Ayuh,..The gimbel bearings are still the same, no problem there...
Seals,+ gaskets,.. I donno...
The shift cable will have to be Up-dated,...
Ya lost me there...
No,.. 10 years Newer, Maybe... 20 years newer, Sure... 30 years newer is still current production...
It's 2" for All of 'em...
rodbolt
I think the old 1966 type 1 still used the gimbal bearing with the shim and retaining ring.
may be hard to find.
I just hope you dont also have the renault 4 cyl 90 hp engine.
gmaster
Yes it does have gimball bearing with the retaining ring. Is this old type of gimball bearing the only one that will work? My engine is a chevy 4 cylinder that is in very good condition. I hope I will be able to find the u-joint and exaust bellows also. I guess I need to start looking for a late model outdrive. Thanks
