patching screw holes
moeMC
will be replacing carpeting in the off season ..is there a product to fill screww holes from the old seats, in the fiberglass floor before in stalling the new carpet ??
Re: patching screw holes
You can use the 2 part marine epoxy that you knead by hand and stuff it in the holes.....
moeMC
cool thanks is that stuf like two color ribons of putty mixed together??
Yeah, walmart has marine epoxy potty, you could even use JB weld but, the marine epoxy dries light grey and blends well. Cheap too!
stevieray
Are you putting the seats back in the same place? If so, you may want to move them just a tad so the screws bite into a fresh area of the floor, rather than the repaired holes. You'll probably find they will hold better if you do.
