Pennzoil synthetic 2 stroke oil
quenston
I just recently bought a boat with a 1989Force 35hp engine, they were running Pennzoil synthetic in it and i was wandering if this is a good oil, i have never had any type of luck with there automotive oils and i was wandering if there 2 stoke oil is any better or if i should change? any advice is greatly appreciated!:confused:
JB
Re: Pennzoil synthetic 2 stroke oil
Pennzoil synthetic is good stuff, Quenston, but expensive.
Any oil rated TC-W3 will work fine in your Force, but synthetics produce less smoke and less stink.
Wow! This is post number 29,000. It scares heck out of me to think how many years on this site that represents.
quenston
Hey thanks for the info appreciate it alot!!!!!
cc67
Do you ever get out on the water?:D
Silvertip
Pennzoil Synthetic is $14.00/gallon at our local Walmart. Hardly what I call expensive when one considers all the outboard manufacturers oils are over $20.00. But then theres always conventional Citgo, Ship Mate, and others available at farm and discount centers for about $8.00/gallon. As mentioned, any TCW3 branded two stroke oil will work fine in your engine. I use Pennzoil Semi-synthetic in mine. Bought every gallon they had for $7.00/gallon last winter.
