PERKO BATTERY SWITCH
Status
Not open for further replies.
Pan-one
Disconnected my battery switch and forgot how to hook it back up again? <br />PERKO SWITCH (OFF / #1 / ALL / #2)<br /><br />I can't find a diagram anybody have one..THANKS!
Chuck_R
Re: PERKO BATTERY SWITCH
I have a 2 battery system, with a #1,2,both and off Perko switch. I am also installing a Newmar Isolator into the system. The engine is a 5.0 302 Ford without all the fancy electronics. What I would like is a little sketch showing the proper way to do this. I also would like some ideas as to where in the system I can tap into to run all my lelctronics and such. I want to be able to shut everything down using the Perko switch.
Thanks
C-note
Ayuh,.... Good mornin' Chuck, 'n Welcome Aboard....
If you start a thread of yer own, insteada hy-jackin' an old antique like this 1,...
You'll get All kinds of answers...
Thank you...
Status
