pitch question???
boatman1971
ok im gonna change the prop on my boat its a 17.5 bass tracker with a 45 hp merc,its very slow to get on plane.to speed is about 25mph,but rpms is about 5000.so heres my question it has a 10 3/8 x13 p should i go to a 11 pitch or 15 pitch?im trying to get it to 5500 rpms and want it to take off a little faster.
Re: pitch question???
Ayuh,.... Less pitch equals more rpms...
boatman1971
so if i put on a 11 pitch it will turn more rpms,but will be slower on top end?
Titanium48
More RPM? Yes. Slower top speed? Maybe, maybe not. It's unlikely to get faster, but it might not slow down much either.
steelespike
Be sure the motor is at the right height.The antivent plate(just above the prop) even with or slightly above the bottom.Throttle opening all the way,move some weight forward.Adjust trim carefully.
Dissregarding slip it does appear that you may lose about 2 mph But that may vary as the prop is closer to its ideal rpm range
thus possibly developing more lift and less slip.
cdn-pk
i agree with steelspike if the motor is too low it'll take forever to jump on plane but other info...
if you need more bow lift or less rpm increase you can look for a prop which is cupped.
example i went from 19 pitch to a 17 pitch i increases 400 rpm and lost 2mph wot. i then tried a 17 pitch with cupped blades, my comparison to the 19 pitch is 150rpm increase and maybe 1mph loss at wot. but i still pop on plane much much faster than the 19 pitch.
hope it helps.... when it comes to props you have many, many choices!
cheers
