Planning question,water spray
Darryl34
I have a 16 foot Aquastar tri hull with a 115 merc.new out,I noticed at wot I have water coming up at the rear and spraying off my tilt shocks.Why? Boat seems to be planning level etc any Ideas???????
LubeDude
Re: Planning question,water spray
Engine too low maybe, Ive experienced that for that reason.
Yep,<br />Move the motor Up an inch,+ It'll go away.......
Darryl34
My cavitation plate is even with the bottom of boat right now???????
That Maybe........<br />Moving it Up will Still Probably fix your Problem..........
Dhadley
Is there anything bolted to the motor? What else is attached to the transom?
Old Jarhead
Cavitation plate even with the keel is really just a starting point. <br /><br />Different boat/engine combo's will need to be adjusted for proper performance. :)
Darryl34
nothing else is bolted to the transom or motor
Dhadley
No fin on the cavitation plate, no speedometer pick up, no transducer -- nothing?
rickdb1boat
What happens if you trim it out further? Or if you trim it back down? Better when out further??
