Play in steering
Nathan k
Just viewed a boat and i think i have finally found the one...3.7 litre picton bowrider and will do 50mph and yet there is still plenty of space with a fully open bow.
there is only one thing i noticed on this boat, the steering had alot of play in it. :(
is that a big problem to fix?
there are plenty of other bowriders out there so if it is a sign that the rest of the boat needs work then i don't mind saying no to this one
Looking foward to your reply :)
Nathan
Re: Play in steering
At low speed it is common to wander.......... That is an IO trait. At high speed it is a problem what Motor is in that boat and what drive? I am not sure what a 4.7 is and if it is a 3.7 I would be VERY VERY hard pressed to buy it
Nathan k
Sorry it IS a 3.7 inboard. do you recommend staying away then?
I have only viewed it out the water and the steering felt loose and unresponsive
Nathan, some (1/4"-3/8") play is normal in a rack and pinon system. If the steering is hydraulic, and it had a lot of play, there is likely a problem, but it should be fixable.
BTW - if you are using the 50MPH speed as part of your decision to buy the boat, I would double check it with a GPS. There are not many boats with that power that go that fast.
TilliamWe
Banned
...3.7 litre...
1. RUN AWAY!!!!!
2. RUN AWAY
3. It can be a $2500 repair if it's so worn out that parts have to be replaced.
Keep looking. The motor alone enough reason to run away from that boat. With a worn gimbal, don't look back.
saclass
what kind of boats are you playing with? I wouldnt buy one that didnt push 50.
boatnut74
For one, 50 is a little fast for fishing. Two, I wouldn't want to go tubing or skiing at 50. However, I do like the adrenaline rush :D
I am not sure of your experience, but 50 MPH is faster than most boats with stock power will achieve. There are some high performance boats and bass-type boats that will achieve higher speeds, but not your average runabout.
Can you rig one to achieve that speed, absolutely. Can you do it with a 3.7l inboard or I/O motor, yes but it would need to be a pretty light boat. This set-up would be pretty rare out of the factory, IMHO.
BTW 50 MPH is good for bare-foot waterskiing....
Nathan k
Thanks for the advice everyone,
In the end i didn't feel it was worth the risk if a repair could cost as much as the boat itself!
Back to E bay and boatsandoutboards! :p
