I just snapped a piece of the starter housing trying to tighten my flywheel nut. I should of put the screwdriver on the gear spindle. Instead I used a piece of the housing that was sticking up behind the gear. I doesnt look like it does anything. Will everything still work? Can the white metal be welded or sould it be replaced. What should I do? Please assist. Thanks
