Please help with Ideas on Hiding Wires on Jon Boat
catfighter
I have these wires hanging on the outside of my boat, under the lip. They go to the trolling motor, the bow lights, and the sonar:
Any suggestions on how to hide them so they don't hang down? I thought about maybe epoxying in a conduit or something. . . I dunno. Right now I have holes drilled for zip ties but they end up breaking after a couple months of UV exposure.
Let me know if you have any suggestions; I'm sure i'm not the first person to deal with this issue.
Thanks!
Re: Please help with Ideas on Hiding Wires on Jon Boat
Conduit will work and then bolt the conduit with SS screws/bolts.
If the zip ties are wasting away from UV I bet they are white ;) try black ones.
Yacht Dr.
I dunno ..This is a first for me ..
Never seen wires running under the hull deck joint on the Outside ! ( what an Overbite )
What kinda boat is this thing ? Do you have an over all pic of the boat ?
YD.
jbcurt00
Yeah, what the heck is this? When you shoot some overalls for YD, shoot a couple of the interior...from 1 side, stern & bow...
colbyt
Thanks!
Never seen it done quite that way before.
I was wandering the electrical aisle at Lowes today trying to figure out a decent way to do it on the inside of the boat. Most conduit is either too big or inflexible; then I had a brain phart because I was holding the answer in my hand from the plumbing department. May I suggest using whichever size clear tubing or the fiber reinforced for a few pennies more that will hold all your wire (.25-.37 per foot). Due to the limpness you may need to support it every 12" with the correct size able strap. I would use plastic and SS screws or rivets.
catfighter
Seriously, I thought about clear tubing!! I think that's the route I'm going as I already have the holes to brace the tubing up with zip ties.
You guys have never seen a Catfighter before?? You're missing out! LOL it's a 1984 Sears Gamefisher.
Here are two more pictures of the boat.
and here it is going up the river:
http://www.youtube.com/watch?v=oBeZjaA76VM&feature=plcp
And, finally, a link to Restoration2012's finished product (most likely the best fiberglass gamefisher you'll ever see):
http://forums.iboats.com/showthread.php?t=530158&page=3
I decided to put the wires on the outside so I don't ever have to worry about tripping on them at night when I'm catfishing.
Yacht Dr.
Well..you could use some plastic electrical conduit .. then attach with some conduit straps and through bolts ?
YD.
catfighter
I figured it out; I bought some stiff refrigerator tubing that I was going to use as a conduit, but then decided to just zip tie it to the wires, and then connect the wires to the rub rail. NOw they don't hang down (which was the issue).
I would have used conduit but I didn't want to have to re-run all the wires inside the conduit. . . .
Thanks for the suggestions
