Plugs, Wires for 89 force 125
Reel-Fun
Any recommended place for Plugs and Wires for a 89 Force 125?
all the marine places near me dont have them and don't really want to help me find them...
Re: Plugs, Wires for 89 force 125
Best to stick with carb kits directly from Mercury.
Guys have been having trouble with the aftermarket kits.
plugs Champion ul18v or NGK BUHW
Not sure, but are the plug wires permanently attached to the coils?
If you replace them, use solid wire core wire, not automotive wires.
Mercury carb kit is part number FK10103-2
Or you can order online from mercruiserparts (dot) com
Reel-Fun
Yes they are how would i change those?
On some of them, you can unscrew the wire from the coil.
On others they pry off.
And some are permanently attached.
I guess the trick is to see if you can get them off without damaging them, just in case they are permanently attached.
