PM Problem
BillP
I received a PM today and the editor will not take my reply. I can start a PM but cannot reply. Is this a fix for this?
Thanks,
Bill
southkogs
Just sent you a PM. Try logging out of iBoats and then logging back in, then see if you can respond to the PM. Not sure why you're not able to reply.
GA_Boater
Thanks,
Bill
Bill - Are you getting an error message when you try to reply?
southkogs
He was missing the "reply" button on a PM the other day. We're sending a couple back and forth to see if it's working right now.
southkogs
One worked fine ... I've sent another test over and we'll see what happens.
toneeees
Administrator
Thanks for working on this, let me know if theres anything I can do.
BillP
I responded on pm but thought it may be a good idea to post an update here too. The reply menu wasn't coming up before but does now. I'm able to reply to PMs again.
Thanks,
Bill
toneeees
Administrator
Thanks,
Bill
Thanks for the update. Glad you were able to get it working again.
