Point Gap 25hp Evin. Mod# 25302
WTDucks
Howdy Boys! <br /><br />Posted up a question a while back about this motor having some sneezing/backfire problem. Just now getting around to working on it. Changed the points & condenser. A gentleman that resided in Denmark had the same motor and recommended that I change the upper crankshaft seal if I saw some wetness around the seal. Well, I did see wetness around the seal and replaced it while I had easy access. Help from Denmark on an outboard motor question!!!! Aint the internet great!!! <br /><br />My question is about the point gap setting. In the manual (Clymer) they recommend using an OHM meter to set the gap/dwell. Can you just set the point gap with feeler gauge? The manual does not have a gap measurement for this motor. My thinking is that if you get the right gap, on the cam there is a set mark, you would get the same result as a dwell meter. Am I off base there? From there my next step would be to "syncronize" the engine as the manual calls it, which I understand is necessary to advance the timing at speed.<br /><br />Can ya just set the point gap at the high/set point on the cam? If so, what would be the proper gap for this motor?<br /><br />Appreciate it!!
rolmops
Re: Point Gap 25hp Evin. Mod# 25302
Up to '72 it was 0.020" I'd say the 73 would be the same.Just double check with a few more reactions.
WTDucks
Well, I found it. Its .020. Didnt think to look on the flywheel. There it was stamped on the thing!!!!! Stupid me!!!
Xcusme
To answer your question..."Can ya just set the point gap at the high/set point on the cam?"<br /><br />Yes, you can.
