Poly/Cotton Boat Cover - can I treat with water repellent ??
MartyTn
Is there a water repellent spray that can be applied to a poly/cotton boat cover to help keep water out?
I've seen products like 303 Fabric Guard and Kiwi Camp Dry that I believe are recommended for canvas / cotton-canvas covers. Can these same products be used on a poly/cotton cover as well? Any other products suggested?
Many thanks,
Marty
Re: Poly/Cotton Boat Cover - can I treat with water repellent ??
Yes, but these spray cans are very expensive.
Your best and cheapest solution is Thompson's water Seal, the same stuff you use on a wood deck.
Brush or roll a couple coats on, and you are good to go.
Thopmson's is a liquified wax in a carrier solution.
It is carried into the fabric threads.
MartyTn
Thanks Roscoe!!
studlymandingo
yes, I use a product by coating technologies. It is a cross-linking polymer system that bonds with the fabric. You can even add a dye to the mixture that will bring the color of the fabric back.
Boatist
I would not waist the money trying to waterproff. Instead save your money and buy a good cover like sunbrella.
