polyester resin
am
I am about to do a rebuild on an old boat(stringers,transom,floor), and im wanting to use polyester resin instead epoxy because of the price.<br /><br />But the question here is, should i follow the same guidelines as in the west systems fiberglass repair booklet with polyester resin?<br /><br />Also i was looking at www.uscomposties.com for ordeing my suplies, anybody oder polyester resin from them, and if so what kind should I get? THANKS ALOT
Re: polyester resin
As in the steps to repair a panel ???.........Ayuh,..... It's Pretty Close to the same.....<br />For Mixing ??..... No,.. Totally Different........<br /><br />The Problem with Mail Order Polyester resin is it's listed as a Hazardous Material.......<br />The Shipping will Kill the deal........<br />Epoxy Doesn't have this Problem..........
blip61
Re: polyester resin
I dont know if you have a Home Depot near you but they sell epoxy and polyester resin pretty reasonable. Just a thought.
jimmythekid
Re: polyester resin
seems home depot stock items what sells in geogrphical areas, no wat do they sell boat resin or marine plywood in grand rapids mich, but they do in bradenton fl.<br /><br />check these guys out: www.fiberglassservices.com<br />they will ship anywhere in fl for free, and they also ship nationwide for a fee. Prices are VERY competitive
Re: polyester resin
AM, Buy the poly resin locally. It is about $15-16/gal around here. For your purposes it is plenty strong IMO. Mix it according to the directions on the resin can(usually +-12 drops hardener/1 oz resin). Use it liberally with plenty of cloth for lateral strength. Make sure everying is dry and clean and sanded with course paper before bonding structural elements. Finer sanding for finish elements of course. if you have a need to create a high strength bond (patch a hole in the hull, for example, you might want to consider using epoxy. You can bond poly resin to cured epoxy if you sand the cured epoxy well and wipe with acetone.
prockvoan
Re: polyester resin
am,were do you live at?Ply resin will work fine.Alot of people don't like it due to the hazard of using it.Know what you are using before doing so.<br />Last boat that I built,I used ply resin for the hole job,2 weeks ago,I was rear ended,my boat was behine me,it took a direct hit to the motor,pushing the boat up 6' on the trailer,stopping at my tailgate.Good thing,the transom held up great.Ply resin with 2 sheets of treated plywood makes it up!Alot was said about both ply resin and treated wood as no good,my boat past the test!Can others say the same!
am
Re: polyester resin
Im in ga, if home depot does carry it that will be great there is one right around the corner. Thanks for the replys
