pontoon distance.. 28ft suntracker..
sptjet90Reflexx
does anyone know the center to center distance on a 1988 sun-tracker party hut pontoon? I have a buyer coming a long way but he wants to make sure it will fit on his trailer. I tried measuring in the water and it appears to be about 76". he said is trailer is 73"
I appreciate it.
I don't know but if he is picking it up from you, why not just go out and measure it?
ahicks
Most commercially available trailers are adjustable. Unless your buyer has a custom or a home built trailer it should be able to be quickly and easily set up for your pontoon.
Jeep Man
Center to center will vary, dependent on tube diameter and whether you have an 8' model or 8.5'. Measure center to center at the front pontoon tip and you have it.
