ported pistons
country boy
I am rebuilding a 1974 115 merc ser#3945429,and i need to change 1 piston that is not a ported piston . i have a crank with pistons for a 1986 merc 90 ser#0a902436 that has ported pistons all seem to be ok on this one .could i swap complete crank or should i change the one piston on the original crank and if i could swap cranks what about the reed cages are they the same from the 90 to the 115.
Faztbullet
Re: ported pistons
Easier to drop the 90 crank assy into block and reed blocks are the same..
