Possible ignition problems
I have a 1991 5.7 350 magnum with thunderbolt ignition alpha one gen one:
I?m having power loss and then stalling issues when the motor gets to normal operating temperature. The engine runs fine after cooling and I suspect the problem is one of the ignition components. I see three but not sure what to start with that could be affected by heat. 1) Distributor pick-up. 2) Ignition amplifier box. 3) Ignition coil. I don?t know how to test any of these components and the motor runs fine sitting at the dock.
Thank you?
Re: Possible ignition problems
I’m having power loss and then stalling issues when the motor gets to normal operating temperature. The engine runs fine after cooling and I suspect the problem is one of the ignition components. I see three but not sure what to start with that could be affected by heat. 1) Distributor pick-up. 2) Ignition amplifier box. 3) Ignition coil. I don’t know how to test any of these components and the motor runs fine sitting at the dock.
Thank you…
Ayuh,.... Here ya go,....
attachment.php
That chart is for the Thunderbolt V, the OP has a Thunderbolt IV.
Here is that chart.
Thank you both! But, now I?m thinking it?s a fuel problem. I tried to get the boat to repeat the symptoms so I could test the ignition today with no luck? (The engine ran perfect)
12 hours earlier running at normal operating temperature the boat was bogging, stalling?loss of power/no power no idle. The boat would run for 30 seconds and then stall.
I ran the boat at the dock for over an hour with no issues when just 12 hours earlier I was being towed back to the marina.
I?m stuck between fuel pump overheat fail or ignition coil overheat failure or possibly some kind of vapor lock in the fuel system. I did notice every time the boat stalled I heard some clicking noise coming from the fuel pump followed by a purging click coming from the fuel tank that stopped as soon as I removed the rubber input fuel line from the tank.
Any ideas?
Any ideas?
Could this be water in the fuel?
achris
More fish than mountain goat
Could be a blocked tank vent!!
