What is the best knot to tie PP to mono on the spool back -up ?
P Pursuit2150 Chief Petty Officer Joined Dec 3, 2001 Messages 553 Apr 26, 2006 #1 What is the best knot to tie PP to mono on the spool back -up ?
rolmops Vice Admiral Joined Feb 24, 2002 Messages 5,723 Apr 27, 2006 #2 Re: Power pro Knot ? Almost any knot will do as long as it is thin enough to easily run through the guides.Just make sure to use superglue on the knot so it will not slip.
JB Honorary Moderator Emeritus Joined Mar 25, 2001 Messages 45,907 Apr 27, 2006 #3 Re: Power pro Knot ? Uni-knot has always worked well for me.
B Backlash Chief Petty Officer Joined May 16, 2001 Messages 586 Apr 27, 2006 #4 Re: Power pro Knot ? Uni-knot unless the diameter of the lines is pretty different...then use the albright.
D DangerDan Petty Officer 1st Class Joined May 21, 2005 Messages 260 Jun 17, 2006 #5 Re: Power pro Knot ? I've always used a palomar for braided line.<br /><br /> http://eaglespark.com/Knots/palomar.htm
A AJ168 Petty Officer 1st Class Joined May 30, 2005 Messages 295 Jun 22, 2006 #6 Re: Power pro Knot ? I like to tie two improved cinches, one on the braid, the other on the mono, through the loop I made with the first knot. It has yet to fail me and it only takes a few seconds to tie.
skimmer Petty Officer 2nd Class Joined Aug 2, 2007 Messages 186 Aug 11, 2007 #7 Re: Power pro Knot ? I use a five turn surgeons, I find when done well it runs through the guides better than any other knot, works well braid to flouro too.
