power steering cooler
K.A.P
Anybody know where I can get a new power steering cooler with water sender on it like this one? Or can I leave the switch off?
Bt Doctur
Have never seen one like that , whats it from, and what material? brass/bronze can be soldered up or brazed. power steering coolers are usually in the raw water inlet side and the only sensor would be a water pressure sensor
achris
More fish than mountain goat
I suspect that's from a Yamaha 4.3 stern drive, but need the OP to confirm before I move it to the Yammy forum...
Bt Doctur
Confirmed Achris, yahama equipment ~~1999 V8_5.0_ENG Yamaha Stern Drive POWER STEERING PUMP - OIL COOLER ...
Capt Ken
That pressure switch tells the computer on the YEMS engine that it has enough water pressure. Take it to a radiator shop and they can repair it.
original construction should have been brazed. that looks like a solder repair. I would keep an eye on it in the future.
