power trim fluid
MATMAN29
98 merc gen 2 Seloc manual say only use 10w30 in a emergency in the trim pump then drain & refill as soon as possible cant find any thing in the merc manual.Is pt fluid absolutly nessecary or will 10w30 do?
Re: power trim fluid
Don't use ATF, here is from an owners manual from Merc. If you put in 10W 30, you do not have to change it.<br /><br />
crazy charlie
ATF sound right for trimtabs.I think my trim pump states 10-20 oil.Charlie
